I was wondering how do I write a program where I can manipulate the degree of polynomial and the lag length of a PDL variable so as to minimize the AIC or SIC for an entire equation. My model has 6 PDL independent variables. The program should also be able to identify the exact equation that minimizes the AIC or SIC.
Thanks.
Polynomial Distributed Lags with minimum AIC or SIC
Hi.
Should be fairly easy to do with a couple of for loops that loop through the combinations of lags and degrees that you want. Below is a simple program that generates some data, then loops through some combinations.
'create some data
create u 1000
series y=nrnd
series x=nrnd
'loop through combinations of lag (1 to 10) and degree of polynomial (1 to 5), finding the equation with the min aic
equation e1
!min_aic = 100000000
smpl 11 @last
for !deg=1 to 5
for !lag=!deg to 10
e1.ls y c pdl(x,!lag,!deg)
if e1.@aic < !min_aic then
!best_lag =!lag
!best_deg = !deg
!min_aic = e1.@aic
endif
'finally estimate equation with the chosen lag/degree combination
e1.ls y c pdl(x,!best_lag, !best_deg)
Re: Polynomial Distributed Lags with minimum AIC or SIC
Its been a long time since I looked at this code, but why does !lag start at !deg? The code says:
equation e1
smpl 11 @last
for !deg=1 to 5
for !lag=!deg to 10
Shouldn't !lag go from 1 to 10?
Thanks for your reply.
equation e1
smpl 11 @last
for !deg=1 to 5
for !lag=!deg to 10
The number of lags has to be greater than the degree of polynomial.
econworker
Hi Gareth, can you tell me how can I generate Impulse Response function graphs from DPL? thanks
There is nothing built in that will do that.
econworker
Thanks Gareth, can you give a hint how can I generate it manually?
