Polynomial Distributed Lags with minimum AIC or SIC
grangel
Postby grangel » Wed Oct 01, 2008 7:41 am
I was wondering how do I write a program where I can manipulate the degree of polynomial and the lag length of a PDL variable so as to minimize the AIC or SIC for an entire equation. My model has 6 PDL independent variables. The program should also be able to identify the exact equation that minimizes the AIC or SIC.
Thanks.
Postby EViews Gareth » Wed Oct 01, 2008 8:28 am
Hi.
Should be fairly easy to do with a couple of for loops that loop through the combinations of lags and degrees that you want. Below is a simple program that generates some data, then loops through some combinations.
'create some data create u 1000 series y=nrnd series x=nrnd 'loop through combinations of lag (1 to 10) and degree of polynomial (1 to 5), finding the equation with the min aic equation e1 !min_aic = 100000000 smpl 11 @last for !deg=1 to 5 for !lag=!deg to 10 e1.ls y c pdl(x,!lag,!deg) if e1.@aic < !min_aic then !best_lag =!lag !best_deg = !deg !min_aic = e1.@aic endif next next 'finally estimate equation with the chosen lag/degree combination e1.ls y c pdl(x,!best_lag, !best_deg)
gcg
Re: Polynomial Distributed Lags with minimum AIC or SIC
Postby gcg » Fri Dec 09, 2011 2:24 pm
Its been a long time since I looked at this code, but why does !lag start at !deg? The code says:
equation e1
smpl 11 @last
for !deg=1 to 5
for !lag=!deg to 10
Shouldn't !lag go from 1 to 10?
Thanks for your reply.
Postby EViews Gareth » Fri Dec 09, 2011 4:52 pm
The number of lags has to be greater than the degree of polynomial.
econworker
Postby econworker » Thu Jan 22, 2015 10:31 am
Hi Gareth, can you tell me how can I generate Impulse Response function graphs from DPL? thanks
Postby EViews Gareth » Thu Jan 22, 2015 10:53 am
There is nothing built in that will do that.
econworker
Postby econworker » Fri Jan 23, 2015 2:19 am
Thanks Gareth, can you give a hint how can I generate it manually?
