I have to test the halloween-effect in Eviews. The halloween-effect means that the returns in the time november-april are higher than in the time from mai-oktober.
What is the right equation for this ?
My proposal is:
Return=c(1)+c(2)*(@month>=11 or @month<=4)
Is this correct ?
Dummy for Halloween-Effect
Re: Dummy for Halloween-Effect
Yes, that will enter a dummy for Nov. - April.
Yes. If C(2) is significantly positive, you will have Halloween effect. Alternatively, you can model without intercept and insert two dummies one for Nov-April and another for may to Oct.Keep in mind, Eviews do no generate F statistics in this case. This is the case of regression through origin.Hi,
My proposal is:
Is this correct ?
