Dummy for Halloween-Effect
Nip
Postby Nip » Sun Nov 27, 2011 7:56 am
I have to test the halloween-effect in Eviews. The halloween-effect means that the returns in the time november-april are higher than in the time from mai-oktober.
What is the right equation for this ?
My proposal is:
Return=c(1)+c(2)*(@month>=11 or @month<=4)
Is this correct ?
Re: Dummy for Halloween-Effect
Postby EViews Gareth » Sun Nov 27, 2011 1:06 pm
Yes, that will enter a dummy for Nov. - April.
nic
Postby nic » Mon Nov 28, 2011 9:27 pm
My proposal is:
Is this correct ?
Yes. If C(2) is significantly positive, you will have Halloween effect. Alternatively, you can model without intercept and insert two dummies one for Nov-April and another for may to Oct.Keep in mind, Eviews do no generate F statistics in this case. This is the case of regression through origin.
