Storing an equation in a Database
donihue
Postby donihue » Sun Nov 13, 2011 7:40 am
According to the online help files for EViews 7.2,
As with other objects, equations may be stored to disk in data bank or database files. You can also fetch equations from these files.
Equations may also be copied-and-pasted to, or from, workfiles or databases.
EViews even allows you to access equations directly from your databases or another workfile. You can estimate an equation, store it in a database, and then use it to forecast in several workfiles.
However, every time I try to do this, I obtain an error message saying
Database error: object 'eq01' is not a database object
I imagine that I am doing something wrong, but it is not obvious what.
[I select the equation in the workfile, right-click, select
Store to DB
, then click
Yes
in the dialogue box. The error message above then follows.]
Can anyone help resolve this, please?
Thanks and regards
Donihue
Re: Storing an equation in a Database
Postby EViews Gareth » Sun Nov 13, 2011 4:36 pm
You're doing it right (and I just did those steps on my copy of EViews, and it worked). Are you sure your copy of EViews is up to date? Are you sure you're storing to an EViews database?
donihue
Postby donihue » Mon Nov 14, 2011 3:37 am
Hello Gareth,
Thanks for your reply. I think you have solved my problem with your query about databases: I was trying to store to a GiveWin database, not an EViews database. It works perffectly when using a native EViews database.
Regards
Donihue
