However, every time I try to do this, I obtain an error message sayingAs with other objects, equations may be stored to disk in data bank or database files. You can also fetch equations from these files.
Equations may also be copied-and-pasted to, or from, workfiles or databases.
EViews even allows you to access equations directly from your databases or another workfile. You can estimate an equation, store it in a database, and then use it to forecast in several workfiles.
.Database error: object 'eq01' is not a database object
I imagine that I am doing something wrong, but it is not obvious what.
[I select the equation in the workfile, right-click, select
, then clickStore to DB
in the dialogue box. The error message above then follows.]Yes
Can anyone help resolve this, please?
Thanks and regards
Donihue
