matrix graphs and individual labeling
tchaithonov
Postby tchaithonov » Mon Jun 06, 2011 3:26 pm
Hi there,
I wonder if there is a way programmatically to label each individual series if I have several columns of data in a matrix and I want to create a line(m) charts. Currently it gives me C1, C2, ... and I notice that there is a way to change individual legends in the gui option, is there one through codes? Please let me know. Thanks.
Tchaithonov
Re: matrix graphs and individual labeling
Postby EViews Gareth » Mon Jun 06, 2011 3:41 pm
The only thing you can do in a program is break out each column as a separate vector, create a graph of that vector, customise the title using addtext(t), then merge all of the graphs into one master graph at the end. Yes, that is painful.
Postby EViews Glenn » Mon Jun 06, 2011 4:59 pm
I may be missing something, but wouldn't
mygraph.setelem(1) legend("Actual Y") mygraph.setelem(2) legend("Predicted Y") ...
set the legends as desired on a *frozen* graph.
Postby EViews Gareth » Mon Jun 06, 2011 5:13 pm
It isn't the legends, it is the titles :(
tchaithonov
Postby tchaithonov » Mon Jun 06, 2011 6:08 pm
So, even though one can manually change the C1, C2, C(i), there is no coding equivalent of that? The thing is, I generated a set of data that is much shorter than the workfile sample. Alright. Guys, thanks anyways.
Postby EViews Glenn » Tue Jun 07, 2011 9:54 am
Ah...I missed the mult part.
Alternately, you can pad the matrix with NA rows to match the current workfile (or better yet copy into an appropriately sized new page). Do a mtos to get the series form, rename the series as desired, then do the graph. Painful, but possibly a bit easier than Gareth's.
