Hi there,
I wonder if there is a way programmatically to label each individual series if I have several columns of data in a matrix and I want to create a line(m) charts. Currently it gives me C1, C2, ... and I notice that there is a way to change individual legends in the gui option, is there one through codes? Please let me know. Thanks.
Tchaithonov
matrix graphs and individual labeling
tchaithonov
Re: matrix graphs and individual labeling
The only thing you can do in a program is break out each column as a separate vector, create a graph of that vector, customise the title using addtext(t), then merge all of the graphs into one master graph at the end. Yes, that is painful.
I may be missing something, but wouldn't
set the legends as desired on a *frozen* graph.
mygraph.setelem(1) legend("Actual Y")
mygraph.setelem(2) legend("Predicted Y")
It isn't the legends, it is the titles :(
tchaithonov
So, even though one can manually change the C1, C2, C(i), there is no coding equivalent of that? The thing is, I generated a set of data that is much shorter than the workfile sample. Alright. Guys, thanks anyways.
Ah...I missed the mult part.
Alternately, you can pad the matrix with NA rows to match the current workfile (or better yet copy into an appropriately sized new page). Do a mtos to get the series form, rename the series as desired, then do the graph. Painful, but possibly a bit easier than Gareth's.
