Diebold_Mariano Test
donihue
Postby donihue » Wed Mar 30, 2011 5:07 am
Would anyone have an EViews code to produce the Diebold-Mariano Predictive Accuracy Test (Diebold, F.X. and R. S. Mariano, "Comparing Predictive Accuracy", J. Bus and Ec Stat, Vol. 13, No. 3, July 1995)?
Regards
Donihue
Savy
Re: Diebold_Mariano Test
Postby Savy » Fri Apr 01, 2011 2:13 am
Hi donihue
In its simple form, the DM test can be calculated by regressing the difference of the loss functions (squared or absolute error) on a constant using Newey-West standard errors
'fc1: Forecast 1 'fc2: Forecast 2 'r: Realised Data ' MSE es_fc1 = (fc1 - r)^2 es_fc2 = (fc2 - r)^2 genr d_squaredloss = es_fc1 - es_fc2 ' MAE ea_fc1 = @abs(fc1 - r) ea_fc2 = @abs(fc2 - r) genr d_absloss = ea_fc1 - ea_fc2 ' DM test equation dm_squaredloss.ls(n) d_squaredloss c equation dm_abs.ls(n) d_absloss c
However, be aware of certain limits of the DM test. For the small sample bias correction, check
Harvey, Leybourne and Newbold, "Testing the equality of prediction mean squared errors", 1998
and for a more general discussion, check e.g.
Giacomini and White, "Tests of Conditional Predictive Ability", 2006
Best
Savy
donihue
Postby donihue » Fri Apr 01, 2011 2:38 am
Many thanks, Savy. That is very helpful indeed.
Regards
Donihue
stasibab
Postby stasibab » Mon Sep 12, 2011 9:00 am
I am trying to use this code for the DM test but I get the error as in the image...
Could you help me?
Postby EViews Gareth » Mon Sep 12, 2011 9:15 am
Put a genr in front of the line that sets them.
stasibab
Postby stasibab » Mon Sep 12, 2011 9:36 am
Thanx Gareth,
I 've done what you said, I pressed run without having any errors but I do not get any results...
Do I have to do something else to see the results?
Postby EViews Gareth » Mon Sep 12, 2011 10:07 am
I don't know enough about the test to say what the results should be. The code generates an equation object, which will be in your workfile. Which of the equation results you need to look at though, I don't know. I'm sure you can figure that bit out though.
stasibab
Postby stasibab » Mon Sep 12, 2011 10:19 am
Dear Gareth, the problem is that I do not get the workfile either...
any ideas why? this is my data
when I press run and I get a new box 'run program' I should just press 'ok' right?
Sorry if the questions are stupid, I am quite a rookie...
r.xlsx
(48.55 KiB) Downloaded 1308 times
fc2.xlsx
(48.61 KiB) Downloaded 1083 times
fc1.xlsx
(48.62 KiB) Downloaded 1138 times
Postby EViews Gareth » Mon Sep 12, 2011 11:36 am
Your screenshot clearly indicates that you have a workfile open.
stasibab
Postby stasibab » Mon Sep 12, 2011 11:39 am
Excuse me bad writing, I meant I do not get the new object into the workfile!
Postby EViews Gareth » Mon Sep 12, 2011 11:41 am
You should have an equation object called dm_squaredloss and one called dm_abs
stasibab
Postby stasibab » Mon Sep 12, 2011 11:44 am
Sorry I run it, I do not get any errors but nothing is added in my workfile... Strange?
Abdelrazzaq
Postby Abdelrazzaq » Tue Sep 30, 2014 8:11 am
I did run the test and had the results. I think the result is not valid enough . t statistic. please find attached.
aexorg.wf1
(562.27 KiB) Downloaded 943 times
Abdelrazzaq
Postby Abdelrazzaq » Wed Oct 01, 2014 1:42 am
please give me some attention
