I am busy with stepwise regression. I have already check that, individually, which variables are significant at a 5% level and then only included those variables in the Stepwise.
However on some of the equations, i am getting null values where in the Std Error, t-stat and prob columns and an R-squared of one.
Do you know why this could be happening? And if so, any tests that should be performed.
Many thanks
Lauren
Interpreting Stepwise result
Re: Interpreting Stepwise result
Could you attach your workfile?
I think it may have something to do with the number of obs left for the stepwise, but I'm not sure. (see s_rev_cbh)
Also another problem I am having is that the stepwise regression does return a result (ie no variables are choosen, with r-squared of 0). However each variable on their own is statiscally significant (see s_capex_avi and s_capex_foodprod)
Your help is much appreciated.
- example.wf1
- (453.04 KiB) Downloaded 243 times
The problem is that you don't have enough valid observations in your sample.
