Interpreting Stepwise result
LaurenF
Postby LaurenF » Tue Feb 01, 2011 11:35 pm
I am busy with stepwise regression. I have already check that, individually, which variables are significant at a 5% level and then only included those variables in the Stepwise.
However on some of the equations, i am getting null values where in the Std Error, t-stat and prob columns and an R-squared of one.
Do you know why this could be happening? And if so, any tests that should be performed.
Many thanks
Lauren
Re: Interpreting Stepwise result
Postby EViews Gareth » Wed Feb 02, 2011 8:53 am
Could you attach your workfile?
LaurenF
Postby LaurenF » Fri Feb 04, 2011 7:35 am
I think it may have something to do with the number of obs left for the stepwise, but I'm not sure. (see s_rev_cbh)
Also another problem I am having is that the stepwise regression does return a result (ie no variables are choosen, with r-squared of 0). However each variable on their own is statiscally significant (see s_capex_avi and s_capex_foodprod)
Your help is much appreciated.
example.wf1
(453.04 KiB) Downloaded 249 times
Postby startz » Fri Feb 04, 2011 7:49 am
The problem is that you don't have enough valid observations in your sample.
