Breusch-Godfrey Serial Correlation LM
tg128
Postby tg128 » Mon Sep 22, 2008 1:34 pm
how can I use the Breusch-Godfrey Serial Correlation LM test in EView 6, what do I suppose to put in the blank area please?
also for the ARCH LM test, what is WGTRESID? is that standarized residual or just squared error terms??
How can I make standarized residual series please?
Postby EViews Gareth » Mon Sep 22, 2008 2:24 pm
Which "blank" area are you talking about? If you're using the Breusch-Goodfrey Serial Correlation LM Test from the menus, there is no "blank" area...
WGTRESID are the residuals, weighted by whatever weight series you used in the original equation.
tg128
Postby tg128 » Tue Sep 23, 2008 8:39 am
Sorry, I meant the Breusch-Pagan-Godfrey test...
Postby EViews Gareth » Tue Sep 23, 2008 8:47 am
Whichever regressors you wish to use in the auxiliary regression for the BPG Test. The standard, text-book, approach is to use the regressors from the original equation (and EViews usually adds those variables to that white box by default).
tg128
thanks
Postby tg128 » Tue Sep 23, 2008 8:54 am
thanks
