how can I use the Breusch-Godfrey Serial Correlation LM test in EView 6, what do I suppose to put in the blank area please?
also for the ARCH LM test, what is WGTRESID? is that standarized residual or just squared error terms??
How can I make standarized residual series please?
Whichever regressors you wish to use in the auxiliary regression for the BPG Test. The standard, text-book, approach is to use the regressors from the original equation (and EViews usually adds those variables to that white box by default).Sorry, I meant the Breusch-Pagan-Godfrey test...Which "blank" area are you talking about? If you're using the Breusch-Goodfrey Serial Correlation LM Test from the menus, there is no "blank" area...
WGTRESID are the residuals, weighted by whatever weight series you used in the original equation.
