Gregory hansen interpretation
jjaa
Postby jjaa » Sun Nov 07, 2010 2:39 pm
I have just run the GH cointegration test but I realley do not understand what i got. could please someone help me? which is the null hypothesis? what is the distribution that it uses?. Please heelp me
Thank you in advance
trubador
Did you use forum search?
Re: Gregory hansen interpretation
Postby trubador » Wed Nov 10, 2010 12:53 am
The same advice applies here as well...
kakali
Postby kakali » Wed Apr 25, 2012 2:16 am
Dear Mr. Tribadator,
I don't know E-views programming. I have been running the Greg-Hansen code which you wrote , have been facing the following problem.
Type Mismatch at Argument 2 in "Call GREGHANSEN (y, x, 3, "AIC", 6)
I am attaching here the prog file and data file.
Your quick response will be appreciated.
Regards,
-Kakali.
gold.xls
(18.5 KiB) Downloaded 699 times
ghtest.prg
(4.8 KiB) Downloaded 639 times
trubador
Postby trubador » Wed Apr 25, 2012 2:39 am
It is not clear what you are asking for here or what you are trying to achieve. If you are trying to build a cointegration model among Gold, NYSE and CPI then you should first decide your dependent (Y) variable. And then you should group other variables as independents (X). For instance:
group independents independents.add nyse cpi call greghansen(gold,independents,3,"aic",6)
