I have just run the GH cointegration test but I realley do not understand what i got. could please someone help me? which is the null hypothesis? what is the distribution that it uses?. Please heelp me
Thank you in advance
Gregory hansen interpretation
Re: Gregory hansen interpretation
The same advice applies here as well...
Dear Mr. Tribadator,
I don't know E-views programming. I have been running the Greg-Hansen code which you wrote , have been facing the following problem.
Type Mismatch at Argument 2 in "Call GREGHANSEN (y, x, 3, "AIC", 6)
I am attaching here the prog file and data file.
Your quick response will be appreciated.
Regards,
-Kakali.
Regards,
-Kakali.
- gold.xls
- (18.5 KiB) Downloaded 701 times
- ghtest.prg
- (4.8 KiB) Downloaded 641 times
It is not clear what you are asking for here or what you are trying to achieve. If you are trying to build a cointegration model among Gold, NYSE and CPI then you should first decide your dependent (Y) variable. And then you should group other variables as independents (X). For instance:
group independents
independents.add nyse cpi
call greghansen(gold,independents,3,"aic",6)Return to “Econometric Discussions”
