pane logit
brozka
pane logit
Postby brozka » Mon Jan 05, 2009 9:29 am
Dear all,
Do you know what is the program syntax when estimating logit model using panel data - Example would be great..
Thank you...
Re: pane logit
Postby EViews Gareth » Mon Jan 05, 2009 9:50 am
The syntax is the same as for non-panel equations:
equation eq1.binary(n=l) depvar c expvar
You should note that EViews does not perform any specialised panel logit estimation - it just treats the data as stacked data (with the exception that lags and leads will not cross over cross-sections).
