Dear all,
Do you know what is the program syntax when estimating logit model using panel data - Example would be great..
Thank you...
pane logit
Re: pane logit
The syntax is the same as for non-panel equations:
equation eq1.binary(n=l) depvar c expvar
You should note that EViews does not perform any specialised panel logit estimation - it just treats the data as stacked data (with the exception that lags and leads will not cross over cross-sections).
