I use the following model:
dep c var1 var2 var3...... AR(1)
When running this regression for my complete sample (1998 2009) I see that Eviews has automatically adjusted the sample to 1999 2009.
To compute the descriptive statistics I first select all my variables (dep, var1, var2, var3, etc) and open them as a group. Next, I adjust my sample to 1999 2009 using the sample button and as a last step I click on view descriptive stats > common sample.
However, EViews uses a different number of observations for the regression (equation) than for descriptive statistics. The problem is solved when I estimate my regression without AR(1).
What I would like to do is compute descriptive statistics using the observations EViews used in the regression I specified.
Thank you for your help!
Lennart
Descriptive statistics when using AR(1) model
After estimating, set the sample to be
which is an easy way of setting it equal to just the observations used
If resid<>na
