Descriptive statistics when using AR(1) model
lentjeuhz
Postby lentjeuhz » Wed Aug 25, 2010 4:22 am
I use the following model:
dep c var1 var2 var3...... AR(1)
When running this regression for my complete sample (1998 2009) I see that Eviews has automatically adjusted the sample to 1999 2009.
To compute the descriptive statistics I first select all my variables (dep, var1, var2, var3, etc) and open them as a group. Next, I adjust my sample to 1999 2009 using the sample button and as a last step I click on view descriptive stats > common sample.
However, EViews uses a different number of observations for the regression (equation) than for descriptive statistics. The problem is solved when I estimate my regression without AR(1).
What I would like to do is compute descriptive statistics using the observations EViews used in the regression I specified.
Thank you for your help!
Lennart
Postby EViews Gareth » Wed Aug 25, 2010 6:58 am
After estimating, set the sample to be
If resid<>na
which is an easy way of setting it equal to just the observations used
