INSTALLATION ISSUES
sudheshna
INSTALLATION ISSUES
Postby sudheshna » Thu Feb 08, 2024 9:26 am
I am trying to install Eviews 12SV but I keep getting below error.
Screenshot (59).png (17.13 KiB) Viewed 55646 times
Re: INSTALLATION ISSUES
Postby EViews Gareth » Thu Feb 08, 2024 10:51 am
It looks like you're running the patch installer, rather than the full application installer.
sudheshna
Postby sudheshna » Thu Feb 08, 2024 10:17 pm
Hello, i downloaded it from the link sent by you guys along with the serial number. I am pretty sure that it's not the patch installer but if it really is a patch installer, could you please direct me to the full application installer?
Postby EViews Steve » Sat Feb 10, 2024 9:10 am
The 12 SV installer is getting confused by a previous failed installation. You'll need to clear some settings in your Windows registry before you can re-run the installer.
Here's the REG zip file. Download and extract the REG file, then double-click it to run. Proceed thru any security warnings and allow it to make changes to your registry. Once complete, re-run the 12 SV installer and it should work this time.
sudheshna
Postby sudheshna » Sun Feb 11, 2024 12:49 am
It worked! Thank you!!
