Dummy variable UP/Down
Sima77
Postby Sima77 » Mon Jul 24, 2023 8:01 am
Hi, I have multiple time series of stock returns, I want to create dummy variables that are 1 when the return increase and 0 when the return decrease. The problem am facing when the returns is the same for several months. For instance, the returns for the following 7 months are 3,4,2,5,5,5,5, I want the dummy variable to be 1 for the last 4 months and not only for the fourth month. Please I would appreciate any help.
Re: Dummy variable UP/Down
Postby EViews Gareth » Mon Jul 24, 2023 8:15 am
When you create your dummy variable, instead of using ">", use ">=" instead.
Sima77
Postby Sima77 » Mon Jul 24, 2023 8:41 am
Thanks for reply. I used this command: series dummy=@recode(y>=y(-1),1,0), but I still have the same problem.Please can you advice?
Postby EViews Gareth » Mon Jul 24, 2023 9:00 am
It works.
wfcreate u 7 series y y.fill 3,4,2,5,5,5,5 series dummy = @recode(y>=y(-1),1,0) show dummy
Sima77
Postby Sima77 » Mon Jul 24, 2023 9:56 am
Sorry, It is my bad that I did not well explain what I want to do. I attached an Excel file in which I typed the Dummy that I want. Please can you help which code can do that? Much appreciated,
Dummy.xlsx
Dummy
(15.71 KiB) Downloaded 1294 times
Sima77
Postby Sima77 » Tue Jul 25, 2023 6:57 am
I would appreciate it if I get a reply to my question.
Postby startz » Tue Jul 25, 2023 7:02 am
Gareth's suggestion does what you ask. In your file you have the dummy stay zero if the return stays constant after it first falls. Is that what you want?
Sima77
Postby Sima77 » Tue Jul 25, 2023 8:35 am
Yes, I want the dummy to stay constant (0 or 1) if the return stays constant. Please can you help?
EViews Matt
Postby EViews Matt » Tue Jul 25, 2023 1:13 pm
Building on Gareth's example, a self-referential expression lets you maintain the previous dummy value in the case that the return is constant.
series dummy = @recode(y>y(-1),1,@recode(y<y(-1),0,@nan(dummy(-1),1)))
Sima77
Postby Sima77 » Wed Jul 26, 2023 10:41 am
Amazing, this is exactly what I want. Thanks.
