Dummy variable UP/Down
Hi, I have multiple time series of stock returns, I want to create dummy variables that are 1 when the return increase and 0 when the return decrease. The problem am facing when the returns is the same for several months. For instance, the returns for the following 7 months are 3,4,2,5,5,5,5, I want the dummy variable to be 1 for the last 4 months and not only for the fourth month. Please I would appreciate any help.
Re: Dummy variable UP/Down
When you create your dummy variable, instead of using ">", use ">=" instead.
Thanks for reply. I used this command: series dummy=@recode(y>=y(-1),1,0), but I still have the same problem.Please can you advice?
It works.
wfcreate u 7
series y
y.fill 3,4,2,5,5,5,5
series dummy = @recode(y>=y(-1),1,0)
show dummy
Sorry, It is my bad that I did not well explain what I want to do. I attached an Excel file in which I typed the Dummy that I want. Please can you help which code can do that? Much appreciated,
- Dummy.xlsx
- Dummy
- (15.71 KiB) Downloaded 1294 times
I would appreciate it if I get a reply to my question.
Gareth's suggestion does what you ask. In your file you have the dummy stay zero if the return stays constant after it first falls. Is that what you want?
Yes, I want the dummy to stay constant (0 or 1) if the return stays constant. Please can you help?
EViews Matt
Building on Gareth's example, a self-referential expression lets you maintain the previous dummy value in the case that the return is constant.
series dummy = @recode(y>y(-1),1,@recode(y<y(-1),0,@nan(dummy(-1),1)))
Amazing, this is exactly what I want. Thanks.
