Problem when programming with python in EVIEWS 12
francisco
Postby francisco » Wed Mar 23, 2022 8:47 am
I am trying to run the following code in Python from EVIEWS 12
xopen(p) xon import numpy as np import pandas as pd import itertools from prophet import Prophet xoff xon param_grid = {"changepoint_prior_scale": [0.001, 0.01, 0.1, 0.5], "seasonality_prior_scale": [0.01, 0.1, 1.0, 10.0]} xoff xon all_params = [dict(zip(param_grid.keys(), v)) for v in itertools.product(*param_grid.values())] xoff
however, it sends me the following error
The same thing happens to me if I use Python 3.8 or 3.9.
Could you please help me identifying where the error is?
Francisco
Re: Problem when programming with python in EVIEWS 12
Postby EViews Steve » Sat Mar 26, 2022 4:45 pm
Did you try running the Python commands within Python directly without using EViews? If so, does it give you the same error?
When you do this, make sure you're using the same Python environment that EViews is talking to. EViews does a few things behind the scenes during a Python command, but this usually only done when going an XGET or XPUT call, not when simply running a Python command within XON.
The reason I mention this is because your screenshot is strange in it is showing a Python command (last red line) that isn't in the original EViews program you showed at the top of your post (the line starting with 'all_params ='). Was this line actually in your program and you forgot to include it or did this line just appear out of nowhere?
Finally, I noticed you're using a Python environment under Anaconda. To make sure you have access to all the same Anaconda managed Python libraries, update your EViews 12 to the latest version, then open an Anaconda command prompt, switch/activate to the proper 'time_series' environment, then launch EViews from that same command prompt so that EViews 12 is using the same environment variables that Anaconda sets up. Refer to this previous post that discusses using EViews with Anaconda.
francisco
Postby francisco » Sat Mar 26, 2022 7:26 pm
Thanks for your response Eviews Steve... I'm going to answer your questions.
YES and is OK
Yes I using the same Python environment… see pictures below.
Here is the image with code posted…
Yes, that's how i'm doing it
As you can see, the code runs in Python environment time_series, but not when I want to run from EVIEWS 12.
Postby EViews Steve » Sat Mar 26, 2022 8:14 pm
What's the build date of your EViews 12? Is it the latest version?
I'll try to reproduce the issue on Monday to see if I can figure out what's going on. But usually that Traceback error is something that is being reported by Python and not something internal to EViews. I would try to see if using a generic Python installation behaves differently from the Anaconda one. Perhaps I'm not transferring enough environment variables from EViews to our Python interface to get Anaconda to work entirely.
francisco
Postby francisco » Sat Mar 26, 2022 9:04 pm
Ok, I really appreciate your help EViews Steve.
This is the version of EVIEWS 12 i have,,,
Postby EViews Steve » Tue Mar 29, 2022 10:04 am
After some extensive testing, I believe this error is being caused by our Python interface not supporting for loops, such as this:
xon letters = ['a','b','c'] for x in letters print(x) xoff
Even if you were to place all the lines of a for loop into a single line, like this:
xon letters = ['a','b','c'] for x in letters: print(x) xoff
You would still get an error when trying to run it thru our Python interface:
One possibility is to use an EXEC command for the single-line for loop, like this:
xon letters = ['a','b','c'] exec('for x in letters: print(x)') xoff
which results in this:
But using this method with your final command line didn't work, most likely due to the strange way the for loop is being used. Instead, I got the following to generate the same all_params value:
xon param_grid = {"changepoint_prior_scale": [0.001, 0.01, 0.1, 0.5], "seasonality_prior_scale": [0.01, 0.1, 1.0, 10.0]} all_params = [] exec('for v in itertools.product(*param_grid.values()): all_params.append(dict(zip(param_grid.keys(), v)))') xoff
francisco
Postby francisco » Tue Mar 29, 2022 11:20 am
Thanks Steve,
I did what you say and it works... from now on I'll use the exec function when I have similar problems.
I usually program in python using Eviews to import machine learning models that are not in Eviews, and what you just told me helps me a lot.
Francisco
Postby EViews Gareth » Tue Mar 29, 2022 1:49 pm
Would you mind mentioning which machine learning models you're using? (in case we want to add them :) )
francisco
Postby francisco » Tue Mar 29, 2022 2:23 pm
Machine learning and deep learning models useful for forecasting time series, such as NnetAR, Prophet and NeuralProphet models, and models in the GluonTS library such as DeepAR, N-Beats, LSTM and the LigthGBM models.
I also use Python or R programming for feature engineering tasks.
If EVIEWS could run any of these models internally I would be very happy.
Francisco
