parameter initialisation
paolo.zanghieri
Postby paolo.zanghieri » Thu Aug 26, 2021 2:14 am
I am trying to estimate an ordered model using a panel dataset. I'd like to add country dummies with the @expand(id01) command. I initialised the parameter but when i run the prg it seems that this is ignored. Is the model too complex? (wf and prg attached)
thanks a lot
panelmodel.wf1
(12.9 MiB) Downloaded 744 times
2_panelmodel_ord_test.prg
(1.4 KiB) Downloaded 709 times
EViews Matt
Re: parameter initialisation
Postby EViews Matt » Thu Aug 26, 2021 3:15 pm
Ordered models have an extra degree of freedom I believe, so this may be an instance of the dummy variable trap. Try @expand(var01, @droplast) instead.
paolo.zanghieri
Postby paolo.zanghieri » Mon Aug 30, 2021 4:53 am
It works
thanks a lot
