I am trying to estimate an ordered model using a panel dataset. I'd like to add country dummies with the @expand(id01) command. I initialised the parameter but when i run the prg it seems that this is ignored. Is the model too complex? (wf and prg attached)
thanks a lot
parameter initialisation
paolo.zanghieri
- panelmodel.wf1
- (12.9 MiB) Downloaded 744 times
- 2_panelmodel_ord_test.prg
- (1.4 KiB) Downloaded 709 times
EViews Matt
Re: parameter initialisation
Ordered models have an extra degree of freedom I believe, so this may be an instance of the dummy variable trap. Try @expand(var01, @droplast) instead.
paolo.zanghieri
It works
thanks a lot
thanks a lot
