saving all equations as tables in a workfile
is there any command to save all equations as tables in a workfile with the same name as equation
Re: saving all equations as tables in a workfile
A combination of @wlookup, a for loop and
freeze(tabname) eqname.results
%eqlist=@wlookup("*","equation") 'make a list of all equations in workfile
for !i=1 to @wcount(%eqlist) 'cycle through the list one at a time
freeze(tabname) eq{!i}ardl_a.results
!rowcounter = !rowcounter+1
next-
!rowcounter =1
freeze(table{!i}ardl_a) eq{!i}ardl_a.results
nextIS THERE ANYWAY THAT WE CAN COPY ALL TABLES TO WORD DIRECTLY FROM A WORKFILE
You might try saving the tables in a spool and then saving the spool in .rtf format.
ANY EXAMPLE WILL BE HIGHLY HELPFUL
thankyou it helped me alot;;its easier instead of copying one by one
