saving all equations as tables in a workfile
adarshad
Postby adarshad » Thu Apr 29, 2021 6:27 pm
is there any command to save all equations as tables in a workfile with the same name as equation
Re: saving all equations as tables in a workfile
Postby EViews Gareth » Thu Apr 29, 2021 7:51 pm
A combination of @wlookup, a for loop and
freeze(tabname) eqname.results
adarshad
Postby adarshad » Fri Apr 30, 2021 9:09 am
%eqlist=@wlookup("*","equation") 'make a list of all equations in workfile for !i=1 to @wcount(%eqlist) 'cycle through the list one at a time freeze(tabname) eq{!i}ardl_a.results !rowcounter = !rowcounter+1 next
what is tabnamehere..my workfile is ARDL&
Postby EViews Gareth » Fri Apr 30, 2021 10:21 am
adarshad
Postby adarshad » Sun May 02, 2021 12:48 pm
!rowcounter =1 %eqlist=@wlookup("*","equation") 'make a list of all equations in workfile for !i=1 to @wcount(%eqlist) 'cycle through the list one at a time freeze(table{!i}ardl_a) eq{!i}ardl_a.results !rowcounter = !rowcounter+1 next
I used this program to store my equations
IS THERE ANYWAY THAT WE CAN COPY ALL TABLES TO WORD DIRECTLY FROM A WORKFILE
Postby startz » Sun May 02, 2021 5:25 pm
You might try saving the tables in a spool and then saving the spool in .rtf format.
adarshad
Postby adarshad » Mon May 03, 2021 7:33 am
ANY EXAMPLE WILL BE HIGHLY HELPFUL
adarshad
Postby adarshad » Mon May 03, 2021 12:09 pm
thankyou it helped me alot;;its easier instead of copying one by one
