using upper() on a series?
dsdsdsdsd
Postby dsdsdsdsd » Fri Sep 11, 2020 9:10 am
hello ...
I am attempting a copy() between two pages ... I believe the problem is case sensitivity between the @src and @dest ... I tried
copy() ... ... @src @upper(country) ...
where 'country' is the source series with lowercase, but of course upper() is not intended to work on a series ...
copy() pg_patents_panel\patents pg_main\patents @src country var01 @dest country dateid
Is there a way to handle the case issue using copy()?
- thanks for your time,
- Shannon
Re: using upper() on a series?
Postby EViews Gareth » Fri Sep 11, 2020 9:13 am
You can use @upper on a (alpha) series, but you cannot use it inline in the copy command.
Create a new alpha that is equal to @upper(country), then use the new alpha as the source id
dsdsdsdsd
Postby dsdsdsdsd » Fri Sep 11, 2020 10:27 am
aha ...
slightly new question: as it turns out I was using that lowercase country as an ID for that table/page ... now that I created the uppercase version, country_U, I may as well get rid of the lowercase series ... but because it is an ID/index column I cannot ... is there a way of doing that??
- Shannon
Postby EViews Gareth » Fri Sep 11, 2020 2:46 pm
You'll have to unstructure the page (i.e. set the page structure to undated or none), change the series, then restructure it.
dsdsdsdsd
Postby dsdsdsdsd » Mon Sep 14, 2020 3:01 am
aha ... fair enough ... thanks ...
