Unable To Execute X-13.exe
livebythecold
Postby livebythecold » Thu Apr 23, 2020 12:38 am
Hello
Whenever I attempt seasonally adjusting a series I get the following Error: Unable to execute X-13.EXE.
I cannot figure out why I get this error.
Any ideas?
Regards
Re: Unable To Execute X-13.exe
Postby EViews Gareth » Thu Apr 23, 2020 8:42 am
EViews version number and which version of Windows?
Postby EViews Steve » Thu Apr 23, 2020 9:00 pm
Make sure your Temp File Path is pointing to a valid writable directory. To see this value, go to Options menu, General Options, File Locations.
Also, specifically for X11, X12, & X13, make sure that your working directory is not more than 4 folders deep (the X?? programs we use do not support a working path that has more than 4 folder names).
For example, a working path such as:
c:\Temp
or
c:\Temp\Folder2\Folder3\Folder4
is ok, but:
c:\Temp\Folder2\Folder3\Folder4\Folder5
is not.
Our default working folder is:
C:\Users\<username>\AppData\ev_temp
where <username> is replaced with your actual Windows username.
livebythecold
Postby livebythecold » Fri Apr 24, 2020 4:40 am
Eviews 11Uni, April 6 2020 Build. macOS Catalina.
c:\Temp
or
is ok, but:
is not.
Thanks. My Temp File Path has 6 folder names. Can I assign a new directory for any folder, say, a desktop folder?
I am using EViews on macOS Catalina.
Postby EViews Gareth » Fri Apr 24, 2020 6:30 am
X-13 doesn’t work on Mac.
