Dear Eviews,
I am facing with EV 11 crash many times when
freeze(fig_name) var_mod.hdecomp(24, g, imp=struct,...)
If I use the GUI it is OK, but anytime I run the code it crashes.
Any idea!?
Eviews 11 crash after freeze hdecomp
Re: Eviews 11 crash after freeze hdecomp
What is the build date of your copy? (Help->About EViews)
binhpham79
Hi Gareth,
The build is the latest. Mar 30, 2020.
Tks!
Tks!
Can you give the whole command you're issuing?
binhpham79
Hi Gareth,
The command likes:
I just copy the command generated from the capture window and add freeze(...)
Thks,
The command likes:
freeze(_fig_hdcomp1) mod_var.hdecomp(24, g, factor=struct, baseline, start=2009m1, end=2012m12, n=1000) x1 @ x1 x2 x3
Thks,
Thanks, we'll fix.
