Eviews 11 crash after freeze hdecomp
binhpham79
Postby binhpham79 » Fri Apr 03, 2020 1:23 pm
Dear Eviews,
I am facing with EV 11 crash many times when
freeze(fig_name) var_mod.hdecomp(24, g, imp=struct,...)
If I use the GUI it is OK, but anytime I run the code it crashes.
Any idea!?
Re: Eviews 11 crash after freeze hdecomp
Postby EViews Gareth » Fri Apr 03, 2020 1:45 pm
What is the build date of your copy? (Help->About EViews)
binhpham79
Postby binhpham79 » Fri Apr 03, 2020 4:06 pm
Hi Gareth,
The build is the latest. Mar 30, 2020.
Tks!
Postby EViews Gareth » Fri Apr 03, 2020 4:48 pm
Can you give the whole command you're issuing?
binhpham79
Postby binhpham79 » Fri Apr 03, 2020 5:44 pm
Hi Gareth,
The command likes:
freeze(_fig_hdcomp1) mod_var.hdecomp(24, g, factor=struct, baseline, start=2009m1, end=2012m12, n=1000) x1 @ x1 x2 x3
I just copy the command generated from the capture window and add freeze(...)
Thks,
Postby EViews Gareth » Fri Apr 03, 2020 7:51 pm
Thanks, we'll fix.
