COM add-in set priority in execution
lgazire
Postby lgazire » Fri Dec 27, 2019 6:46 am
All,
Is there a parameter in the command line for set priority executions to Low?
Best Regards,
Lucas.
Re: COM add-in set priority in execution
Postby EViews Steve » Fri Dec 27, 2019 8:10 am
Not really sure what you're asking, but if it's related to using COM automation to control EViews, there isn't any parameter to tell EViews to run in a lower priority process. Also, if you're launching a program, I don't believe there's a parameter to tell EViews to do the same either.
lgazire
Postby lgazire » Fri Dec 27, 2019 10:07 am
Understood, i thought that due to the high process consumption i could change it via parameter. Thanks!
Return to “Add-in Support”
