All,
Is there a parameter in the command line for set priority executions to Low?
Best Regards,
Lucas.
COM add-in set priority in execution
Re: COM add-in set priority in execution
Not really sure what you're asking, but if it's related to using COM automation to control EViews, there isn't any parameter to tell EViews to run in a lower priority process. Also, if you're launching a program, I don't believe there's a parameter to tell EViews to do the same either.
Understood, i thought that due to the high process consumption i could change it via parameter. Thanks!Not really sure what you're asking, but if it's related to using COM automation to control EViews, there isn't any parameter to tell EViews to run in a lower priority process. Also, if you're launching a program, I don't believe there's a parameter to tell EViews to do the same either.
