naming samples in a program
miorinnovo
Postby miorinnovo » Tue Feb 27, 2018 8:49 am
This is only a a minor annoyance but when I re-run a program that contains a sample I created, the program stops saying that sample already exists. Is there a way around that other than commenting out the sample creation line?
EViews Matt
Re: naming samples in a program
Postby EViews Matt » Tue Feb 27, 2018 10:31 am
You can condition the sample creation statement with an @isobject check, that way the sample object will only be created if it doesn't already exist:
if not @isobject("foo") then sample foo ... endif
If the sample is dynamic (possibly changing each time you run the script), you could do something similar to reset or delete and recreate the sample object instead.
Postby EViews Gareth » Tue Feb 27, 2018 6:31 pm
I always just throw a
D(noerr) objectname
At the top of the program
