This is only a a minor annoyance but when I re-run a program that contains a sample I created, the program stops saying that sample already exists. Is there a way around that other than commenting out the sample creation line?
naming samples in a program
EViews Matt
Re: naming samples in a program
You can condition the sample creation statement with an @isobject check, that way the sample object will only be created if it doesn't already exist:
If the sample is dynamic (possibly changing each time you run the script), you could do something similar to reset or delete and recreate the sample object instead.
if not @isobject("foo") then
sample foo ...
endif
I always just throw a
At the top of the program
D(noerr) objectname
