Import .TXT into table as strings
Postby tvonbrasch » Tue Dec 05, 2017 12:06 am
I want to import a text file into a table object using the command
importtbl(text,name=table) xxx.txt
However, the text for
02
is imported as
2
and
im
as
NA
(see picture below). How can this be imported direcly as a text string?
Re: Import .TXT into table as strings
Postby EViews Steve » Tue Dec 05, 2017 8:50 am
You need to treat the first column as string during the import wizard.
Normally, EViews would automatically determine this, but the row that had character data in the first column was too far down the file and beyond the point in which EViews stops checking for data type.
Specifically, on page 4 of 5, you'll need to change the column data type to Character (click on the first column, then select "Character" as the Data type in the dropdown):
import wizard step 4 of 5.png (9.43 KiB) Viewed 5388 times
The associated captured command will also tell you how to do it programmatically:
wfopen myfile.txt ftype=ascii rectype=crlf skip=0 fieldtype=delimited delim=tab types=(A,) colhead=0 eoltype=pad badfield=NA @id series01 @smpl @all
The "types=" argument is what tells EViews to treat the first column as character data.
Postby tvonbrasch » Thu Dec 07, 2017 7:14 am
hi
thanks for your reply!
i tried your command, but it does not work.....
importtbl(type=text, ftype=ascii rectype=crlf skip=0 fieldtype=delimited delim=tab types=(A,) colhead=0 eoltype=pad badfield=NA @id series01 @smpl @all) .\lister\indeks_c_konsumaktivitet.txt
can you please take a second look at it?
Indeks_c_konsumaktivitet.txt
(471 Bytes) Downloaded 403 times
Postby EViews Steve » Thu Dec 07, 2017 10:51 am
Oops, sorry - I forgot you were trying to create a Table instead of just a workfile.
Here's the command for importing your text file with the first column as text instead of a number:
importtbl(name=mytable) Indeks_c_konsumaktivitet.txt ftype=ascii rectype=crlf skip=0 fieldtype=delimited delim=tab types=(A,) colhead=0 eoltype=pad badfield=NA
EViews created this command for me when I did the following:
1. Open a workfile
2. File menu->Import->Table from file... and selected your text file.
3. Clicked Next until I got to "Step 3 of 4" in the import table wizard.
4. Clicked on the first column (in the bottom preview) and then changed the data type to "Character" in the Data type dropdown. Click Next.
6. Entered "MyTable" as the name of the table. Click Finish.
7. Switched to the Capture window to see the generated command.
Postby tvonbrasch » Thu Dec 07, 2017 12:37 pm
Great Steve, that worked, thanks!
