The following set of commands has blown up EViews three times in a row. (Today's update, running XP)
create u 200
series x=nrnd
series ystar=x
series y=ystar*(ystar>0)
tobit y x c
xopen(type="m",case="lowercase")
blewey!!!!
Re: blewey!!!!
I confirm that this blows up EViews7 (latest update of today) running under Windows7
Regards
Donihue
Regards
Donihue
Re: blewey!!!!
Yep. It is actually the last line, I believe, that is causing the crash. We'll investigate and hopefully have a fix soon.
Re: blewey!!!!
Actually, the command should be this:
The case="lowercase" that you had in your code line triggered the crash in EViews when it tried to report the invalid case option string.
This will be fixed in the next update. However, for now, you might want to try the valid case option.
p.s. I added case="lowercase" and case="uppercase" as valid options in this fix as well so your original codeline should work after the next release...
xopen(type="m", case="lower")This will be fixed in the next update. However, for now, you might want to try the valid case option.
