blewey!!!!
blewey!!!!
Postby startz » Thu Feb 04, 2010 6:30 pm
The following set of commands has blown up EViews three times in a row. (Today's update, running XP)
create u 200
series x=nrnd
series ystar=x
series y=ystar*(ystar>0)
tobit y x c
xopen(type="m",case="lowercase")
donihue
Re: blewey!!!!
Postby donihue » Fri Feb 05, 2010 3:57 am
I confirm that this blows up EViews7 (latest update of today) running under Windows7
Regards
Donihue
Re: blewey!!!!
Postby EViews Gareth » Fri Feb 05, 2010 9:02 am
Yep. It is actually the last line, I believe, that is causing the crash. We'll investigate and hopefully have a fix soon.
Re: blewey!!!!
Postby EViews Steve » Fri Feb 05, 2010 9:15 am
Actually, the command should be this:
xopen(type="m", case="lower")
The case="lowercase" that you had in your code line triggered the crash in EViews when it tried to report the invalid case option string.
This will be fixed in the next update. However, for now, you might want to try the valid case option.
p.s. I added case="lowercase" and case="uppercase" as valid options in this fix as well so your original codeline should work after the next release...
