How to apply the restriction c(2) = c (3)?
Samster
Postby Samster » Thu Jun 08, 2017 2:52 pm
Greetings. The Wald test results accept the null hypothesis of c(2) = c(3). How do I run a regression imposing said restrictions on the coefficients ?
The following options work in that the coefficients (in the regressions with the restrictions) are indeed equal to each other. However, there are differences in the coefficients depending on which of the following is used.
(c(2) > c(3))*X1
or (c(2) >= c(3))*X1
or (c(2) > c(3))*X1 + (c(3) > c(2))*X2
Thanks for your time.
Re: How to apply the restriction c(2) = c (3)?
Postby EViews Gareth » Thu Jun 08, 2017 3:14 pm
What on earth are you trying to do?
If you want to impose the restriction that c(2)=c(3), then just use c(2) for both regressors.
y=c(1)+c(2)*x+c(2)*z
Samster
Postby Samster » Thu Jun 08, 2017 7:14 pm
Thank you very much man.
However, surely your response could have been more professional. "The what on earth" this non-expert Eviews user, non-expert Econometrician, was doing actually yielded coefficients that were identical up to 4 decimal places (see attachment). However, the approach seemed "unstable" so I sought clarity. Indeed, I could not use the equal sign so I tried something else. Next time I will simply bother you, instead of trying to think outside the box.
Do have a pleasant day/evening.
eviews.pdf
(106.4 KiB) Downloaded 321 times
Postby EViews Gareth » Thu Jun 08, 2017 7:21 pm
Criticism accepted
Postby EViews Glenn » Mon Jun 12, 2017 12:09 pm
An even easier one is to modify the regressor to enforce the restriction
y c z (x1+x2)
