Greetings. The Wald test results accept the null hypothesis of c(2) = c(3). How do I run a regression imposing said restrictions on the coefficients ?
The following options work in that the coefficients (in the regressions with the restrictions) are indeed equal to each other. However, there are differences in the coefficients depending on which of the following is used.
(c(2) > c(3))*X1
or (c(2) >= c(3))*X1
or (c(2) > c(3))*X1 + (c(3) > c(2))*X2
Thanks for your time.
How to apply the restriction c(2) = c (3)?
Re: How to apply the restriction c(2) = c (3)?
What on earth are you trying to do?
If you want to impose the restriction that c(2)=c(3), then just use c(2) for both regressors.
y=c(1)+c(2)*x+c(2)*z
Thank you very much man.
However, surely your response could have been more professional. "The what on earth" this non-expert Eviews user, non-expert Econometrician, was doing actually yielded coefficients that were identical up to 4 decimal places (see attachment). However, the approach seemed "unstable" so I sought clarity. Indeed, I could not use the equal sign so I tried something else. Next time I will simply bother you, instead of trying to think outside the box.
Do have a pleasant day/evening.
Criticism accepted
An even easier one is to modify the regressor to enforce the restriction
y c z (x1+x2)Who is online
