addin -nowarn
addin -nowarn
Postby tvonbrasch » Tue Sep 27, 2016 10:26 pm
when I install an addin using the command
addin(type="global", menu = "Lager tabell fra Excel fil", proc="lagtabell", desc="Lager tabell fra Excel fil", version="1.0") "./lagtabell.prg"
i get a warning that the addin is already installed.
However, if I add the nowarn option and use the command
addin(nowarn, type="global", menu = "Lager tabell fra Excel fil", proc="lagtabell", desc="Lager tabell fra Excel fil", version="1.0") "./lagtabell.prg"
i get the option
and nothing happens if I press OK.
Why is this?
Re: addin -nowarn
Postby EViews Gareth » Wed Sep 28, 2016 8:02 am
We'll take a look.
Re: addin -nowarn
Postby EViews Gareth » Thu Sep 29, 2016 8:36 am
We can't replicate this. Are you running the addin command as part of a program?
epikcoding
Re: addin -nowarn
Postby epikcoding » Tue Mar 27, 2018 9:13 am
I'm having the same issue as tvonbrasch. I am running the add-in commands inside a .prg file inside an add-in package.
addin(nowarn, type="global", desc="Open Table", menu="Open Table") ".\Open_Tables.prg"
Re: addin -nowarn
Postby EViews Steve » Tue Mar 27, 2018 10:59 am
What version of EViews are you using? Also, what is the build date? 32-bit or 64-bit?
epikcoding
Re: addin -nowarn
Postby epikcoding » Tue Mar 27, 2018 11:08 am
July 17th, 2017 Build. 64-bit.
Re: addin -nowarn
Postby EViews Gareth » Tue Mar 27, 2018 11:09 am
EViews 9 or EViews 10?
epikcoding
Re: addin -nowarn
Postby epikcoding » Tue Mar 27, 2018 11:11 am
EViews 10
Re: addin -nowarn
Postby EViews Steve » Tue Mar 27, 2018 11:22 am
Ok we'll look into it. It'd be helpful if you sent me your AIPZ file (or whatever you have) so I can test it on my system and try to replicate your problem. If you can, please email it to support@eviews.com and reference this forum post in the email.
Re: addin -nowarn
Postby EViews Steve » Tue Mar 27, 2018 12:02 pm
Ok thanks for the file. I was able to reproduce the issue and I found the bug. It'll be fixed in the next patch.
epikcoding
Re: addin -nowarn
Postby epikcoding » Tue Mar 27, 2018 12:05 pm
Okay thank you! I guess we can expect the patch to come in April?
Re: addin -nowarn
Postby EViews Steve » Tue Mar 27, 2018 12:31 pm
Probably next week.
