Export Graphs to Word Documents
is it possible to export grapgh created with Eviews 8 directly to word documents?
Re: Export Graphs to Word Documents
Can you explain what you mean more?
You've posted this in the programming forum - did you want to do it in a program? There is no way for EViews to control Word programmatically.
I would like to export a graogh of this type
graph Fig.line X Y
directly into word
Currently I do copy/paste
graph Fig.line X Y
directly into word
There is no way for EViews to tell Word to paste something.
However, after you paste a figure into Word you can then open it in a context menu as an EViews object. The object will then open in EViews and you can modify it in EViews and the changes will save into Word.
Additionally, you can save a figure to a file. Then in Word when you Insert a picture, use insert a link instead. If you then save a new version of the file, Word will pick up and insert the new version.
