Export Graphs to Word Documents
RDS
Postby RDS » Fri Sep 16, 2016 10:23 am
is it possible to export grapgh created with Eviews 8 directly to word documents?
Re: Export Graphs to Word Documents
Postby EViews Gareth » Fri Sep 16, 2016 11:01 am
Can you explain what you mean more?
You've posted this in the programming forum - did you want to do it in a program? There is no way for EViews to control Word programmatically.
RDS
Postby RDS » Fri Sep 16, 2016 2:48 pm
I would like to export a graogh of this type
graph Fig.line X Y
directly into word
Currently I do copy/paste
Postby EViews Gareth » Fri Sep 16, 2016 3:01 pm
There is no way for EViews to tell Word to paste something.
Postby startz » Fri Sep 16, 2016 3:51 pm
However, after you paste a figure into Word you can then open it in a context menu as an EViews object. The object will then open in EViews and you can modify it in EViews and the changes will save into Word.
Postby startz » Fri Sep 16, 2016 3:52 pm
Additionally, you can save a figure to a file. Then in Word when you Insert a picture, use insert a link instead. If you then save a new version of the file, Word will pick up and insert the new version.
