script for Johansen cointegration test
eviews1
Postby eviews1 » Mon May 02, 2016 9:18 am
I am looking for a script(code) to automate Johansen cointegration test in Eviews 9 COM Automation.
I was running it using Eviews menu but now I need to run the test with several sub-samples.
Thank you.
Argyn
Re: script for Johansen cointegration test
Postby EViews Gareth » Mon May 02, 2016 9:25 am
Easiest thing to do is to run it via the menus, then use the Command Capture window to view the command line equivalent.
eviews1
Postby eviews1 » Mon May 02, 2016 9:32 am
Thank you very much for your help.
