I am looking for a script(code) to automate Johansen cointegration test in Eviews 9 COM Automation.
I was running it using Eviews menu but now I need to run the test with several sub-samples.
Thank you.
Argyn
script for Johansen cointegration test
Re: script for Johansen cointegration test
Easiest thing to do is to run it via the menus, then use the Command Capture window to view the command line equivalent.
Thank you very much for your help.
