Estimation involved time trend
Hi, I have a question regarding to the estimation involving a time trend.
Let say I had estimated an equation and obtained all the coefficients of the variables such as:
equation.ls y c @trend y(-1)
Coefficients obtained: 0.3 for c; 0.5 for @trend; 1.2 for y(-1).
Now if I want to generate a series based on my estimated coefficients by specifying the equation as
y = 0.3 + 0.5*@trend + 1.2*y(-1).
Unfortunately, the eviews doesn't allow me to generate the series (or observation) mentioned that @trend is a reserved term.
My question is, if I want to generate observation based on my estimated equation, how should I specify in the equation, given that the coefficients information.
Re: Estimation involved time trend
That command is perfectly legal in EViews. So there must be something else funky going on. Exactly what did you type and what error message did you get?Now if I want to generate a series based on my estimated coefficients by specifying the equation as
Hi thank you for your reply.
Actually I am writing a program to help me generate series after I estimated an equation. I am working in this way:
First, I estimate an equation named "Equation" involved a constant, time trend and its lagged variable using least square:
Equation.ls y c @trend y(-1)
After I estimated and obtained the estimated coefficients such as
0.3 for c
0.5 for @trend
1.2 for y(-1)
and I save it.
Next, I try to generate series based on the information above:
for !i=1 to 50
y(!i) = 0.3 + 0.5*@trend + 1.2*y(!i-1)
But when come to this step, I was stopped by the program and telling me that @trend is a reserve term. Then I'm wondering am I wrong in the equation specification and thinking is there any other way for me to generate the series. Hope that my problem is clear for you now.
0.3 for c
0.5 for @trend
1.2 for y(-1)
and I save it.
for !i=1 to 50
As Startz mentioned, it is a perfectly legal command. Something else is going on. Post your entire program.
Hi, below is my simple program. The program couldn't complete due to the problem I mentioned. Hope that you can help to resolve my problem. Thanks.
workfile test u 1000
series y = nrnd
series x = 0
equation estimate.ls y c @trend y(-1)
vector(3) coef
for !i=1 to 3
coef(!i) = estimate.@coefs(!i)
x(1) = y(1)
for !ic=2 to 1000
x(!ic) = coef(1) + coef(2)*@trend + x(!ic-1)
series y = nrnd
series x = 0
vector(3) coef
for !i=1 to 3
x(1) = y(1)
for !ic=2 to 1000
You're working element by element inside your loop, but you're not accessing an element of @trend.
I think you just want:
Or, to make it much simpler:
series y = nrnd
series x = 0
vector(3) coef
for !i=1 to 3
x(1) = y(1)
smpl 2 1000
x = coef(1) + coef(2)*@trend + x(-1)
series y = nrnd
series x
x(1) = y(1)
smpl 2 1000
x = estimate.@coef(1) + estimate.@coef(2)*@trend + estimate.@coef(3)*x(-1)
Thank you for your prompt. May I know is there possible to compile the series by generating its observation one by one using loop? This is because I intend to generate the series recursively in my program.
Example:
Given y = series y; x = series x; resids_y = residual y; resids_x = residual x
for !i=1 to 100
dy(!i) = coef(1) + coef(2)*@trend + coef(3)*y(!i-1) + coef(4)*x(!i-1) + resids_y
dx(!i) = coef1(1) + coef1(2)*@trend + coef1(3)*y(!i-1) + coef1(4)*x(!i-1) + resids_x
y(!i) = dy(!i) + y(!i-1)
x(!i) = dx(!i) + x(!i-1)
I need to generate the observation one by one in order to generate the series y and x properly.
Example:
for !i=1 to 100
I don't understand why you need a loop.
Hi Gareth, because in the generation of series y there is a cross over with series x. In order to get the observation y, we need to first generate the ith observation of dy then only can generate ith observation of y. So in the generating process, I have to complete the whole process in order to get the ith observation.
Example for the program 1:
workfile test1 u 100
rndseed 12345
series resid_y = nrnd
series resid_x = nrnd
series y = 0
series x = 0
series dy = 0
series dx = 0
smpl 2 100
dy = y(-1) + x(-1) + resid_y
dx = y(-1) + x(-1) + resid_x
y = dy + y(-1)
x = dx + x(-1)
is different with the program 2:
workfile test2 u 100
rndseed 12345
series y = 0
series x = 0
series dy = 0
series dx = 0
for !i = 2 to 100
dy(!i) = y(!i-1) + x(!i-1) + resid_y(!i)
dx(!i) = y(!i-1) + x(!i-1) + resid_x(!i)
Both will generate different values for series y and x. Hope that you get my concerns and what I wanted to express. Thanks.
rndseed 12345
series y = 0
series x = 0
series dy = 0
series dx = 0
smpl 2 100
y = dy + y(-1)
x = dx + x(-1)
rndseed 12345
series y = 0
series x = 0
series dy = 0
series dx = 0
for !i = 2 to 100
Simultaneous generation of several dynamic series is one of the things for which the model object is built:
Note that you can simplify the computation (at the expense of clarity) by folding the dy and dx equations into the y and x generating equations.
workfile test3 u 100
rndseed 12345
series y = 0
series x = 0
model a
a.append dy = y(-1) + x(-1) + resid_y
a.append dx = y(-1) + x(-1) + resid_x
a.append y = dy + y(-1)
a.append x = dx + x(-1)
a.scenario "actuals"
a.solve
Ok, I got it now. Thanks lot for your efforts!
