I am trying to decompose changes in income across countries. I have made the graph i want in excel (see below), but I do not know how to make it in Eviews
the data is both in the attached excel file and in the attached Eviews workfile. How do you you make a stacked bar graph like this in Eviews?
stacked bar graph across countries
- decomp_g.xlsx
- (13.93 KiB) Downloaded 264 times
- graph.wf1
- (9.42 KiB) Downloaded 221 times
Re: stacked bar graph across countries
Workfile didn't contain any data.
But just open up the Excel file in EViews, then open up the five series as a group. View->Graph->Bar. Select Multiple Series: Stack in single graph. Switch to the Graph Elements->Bar-Area-Pie page and select "Stack positive and negative values separately".
- decomp_g.wf1
- (19.11 KiB) Downloaded 220 times
thanks for this! very useful!
sorry about the data in the workfile, i only copied the groups.
if you look at the attached workfile, the groups
dec_deu
dec_dnk
dec_swe
dec_usa
contains series for the four countries deu, dnk, swe usa.
to create a stacked bar graph as you showed me (say for year=2013), how should i proceed when the workfile is in this time series format?
should i copy the series to a new page to make it consistent with the organisation in the excel format (and if so, how)? or is there a way to generate the stacked bar graph in the current worrkfile? thanks again!
dec_deu
dec_dnk
dec_swe
dec_usa
i see that i can do the same thing from a matrix
smpl 2013 2013
vector dnk=@convert(dec_dnk)
vector deu=@convert(dec_deu)
vector swe=@convert(dec_swe)
vector usa=@convert(dec_usa)
matrix(4,5) aa
rowplace(aa,dnk,1)
rowplace(aa,deu,2)
rowplace(aa,swe,3)
rowplace(aa,usa,4)
