@wfindnc - bug?
@wfindnc - bug?
Postby tvonbrasch » Thu Dec 17, 2015 2:47 am
try and run the following code where you open the attached workfile:
close @all
%dir=@runpath
cd %dir'"C:\tvb\articles\labour_services\eviews"
wfopen wfindnc
for !i=570 to 571
%eq=kvartstroll.@line(!i)
if @isobject("test")=1 then
delete test
endif
model test
test.append {%eq}
'generate text file with equations where endogenous variable has already been defined
text problemequations
'TRY TO UNCOMMENT THE FOLLOWING LINE:
scalar a_{!i}_=@wfindnc(kvarts.@endoglist,@trim(test.@endoglist))
if @wfindnc(kvarts.@endoglist,@trim(test.@endoglist)) = 0 then
kvarts.append {%eq}
else
problemequations.append {%eq}
problemequations.append {!i}
endif
This creates a blank textfile problemequations. However, if you comment out the scalar a_{!i}_.... line and rerun the program, the textfile problemequations is filled with some text, for some reason. Do you understand what is causing this?
THomas
wfindnc.WF1
(530.82 KiB) Downloaded 243 times
Re: @wfindnc - bug?
Postby EViews Gareth » Thu Dec 17, 2015 10:32 am
We shall investigate.
Re: @wfindnc - bug?
Postby EViews Gareth » Thu Dec 17, 2015 11:26 am
Looks like it is to do with whether the model has been compiled or not - calling @endoglist before compiling isn't going to work very well.
If you modify your code to be:
for !i=570 to 571 %eq=kvartstroll.@line(!i) if @isobject("test")=1 then delete test endif model test test.append {%eq} 'generate text file with equations where endogenous variable has already been defined text problemequations kvarts.update test.update 'TRY TO UNCOMMENT THE FOLLOWING LINE: 'scalar a_{!i}_=@wfindnc(kvarts.@endoglist,@trim(test.@endoglist)) '------------------------------------------------------------------------------------------- if @wfindnc(kvarts.@endoglist,@trim(test.@endoglist)) = 0 then kvarts.append {%eq} else problemequations.append {%eq} problemequations.append {!i} endif next
it should work as expected.
Re: @wfindnc - bug?
Postby tvonbrasch » Fri Dec 18, 2015 6:21 am
Excellent, that worked!
thanks
t
