try and run the following code where you open the attached workfile:
close @all
%dir=@runpath
cd %dir'"C:\tvb\articles\labour_services\eviews"
wfopen wfindnc
for !i=570 to 571
%eq=kvartstroll.@line(!i)
if @isobject("test")=1 then
delete test
endif
model test
test.append {%eq}
'generate text file with equations where endogenous variable has already been defined
text problemequations
'TRY TO UNCOMMENT THE FOLLOWING LINE:
scalar a_{!i}_=@wfindnc(kvarts.@endoglist,@trim(test.@endoglist))
if @wfindnc(kvarts.@endoglist,@trim(test.@endoglist)) = 0 then
kvarts.append {%eq}
else
problemequations.append {%eq}
problemequations.append {!i}
endif
This creates a blank textfile problemequations. However, if you comment out the scalar a_{!i}_.... line and rerun the program, the textfile problemequations is filled with some text, for some reason. Do you understand what is causing this?
THomas
@wfindnc - bug?
@wfindnc - bug?
- wfindnc.WF1
- (530.82 KiB) Downloaded 246 times
Re: @wfindnc - bug?
We shall investigate.
Re: @wfindnc - bug?
Looks like it is to do with whether the model has been compiled or not - calling @endoglist before compiling isn't going to work very well.
If you modify your code to be:
it should work as expected.
for !i=570 to 571
delete test
endif
model test
test.append {%eq}
kvarts.update
test.update
'scalar a_{!i}_=@wfindnc(kvarts.@endoglist,@trim(test.@endoglist))
kvarts.append {%eq}
else
endif
Re: @wfindnc - bug?
Excellent, that worked!
thanks
t
thanks
t
