I'm using a loop to generate then save tables that vary in size to csv files.
Each table varies in dimension - the number of rows and columns differ table to table about 30 or so in total.
I'm usng EV9 - enterprise edition and here is this is the code I use to export the cvs file:
p{%2}.save(r=B8:S15, t=csv, n="NAN") outp{%2}
Is there a trick to programing - ie can "r=B8:S15" definition be altered to a wildcard statement - so the program will read each table in each loop iteration, determine table dimensions then save the table tin csv format?
thanks
program to save tables of various sizes to csv in a loop
Re: program to save tables of various sizes to csv in a loop
I'm not sure I follow. Why do you need to use the r= option at all? You only want to save part of each table? If so, how do you know which part of each table you want to save?
THANKS FOR POINTING THE "R=" OUT - REMOVED IT AND THINGS RUN SMOOTH - DUH...
